I Need Advice on Overclocking My Ryzen 7 5800X
disney3
Hii Guys!?
I recently upgraded my setup with a Ryzen 7 5800X and I'm looking to get the most out of it through overclocking. I have some experience with overclocking my previous Intel CPU, but I'm relatively new to AMD and could use some guidance.
My current build is:
  • CPU: Ryzen 7 5800X
  • Motherboard: ASUS ROG Strix B550-F Gaming
  • Cooler: Noctua NH-D15
  • RAM: 32GB Corsair Vengeance LPX 3200MHz
  • GPU: NVIDIA RTX 3080
  • PSU: Corsair RM850x
I have been able to achieve a stable 4.7GHz on all cores with a Vcore of 1.35V, but I'm curious if there's more potential here. My main questions are:
  1. What’s a safe voltage range for daily use with the 5800X?
  2. Are there any specific settings or tweaks in the BIOS that I should be aware of to improve stability and performance?
  3. Has anyone had better success with Precision Boost Overdrive (PBO) or manual overclocking for this CPU?
  4. What temperatures should I be aiming for under load to ensure longevity?
I also check this: https://www.xtremehardware.com/index.php?option=com_jmap&view=sitemap&format=mobileqlikview But I have not found any solution. Any tips, personal experiences, or resources would be greatly appreciated.
Thank you!
