Project 900D Monster Xtreme
Col. Hannibal
  • Replies 246
Sticavoli!!!!! Fantastici
Grazie caro, spero che anche assemblati siano d'effetto
una valanga di belle cose! seguissimo!
Ora il materiale inizia ad esserci all'85-90% macherebbe Bitspower e/o EK, devo fare gli ultimi ritocchi sulla struttura, le famose parti in plexy e poi iniziare ad assemblare, testare e modificare......
Cioè ancora tanto tanto lavoro ... :nutkick:
e divertimento ! :asd:
Intanto ho rimontato il Banchetto 101 per provare l'Hw questa volta powered by n°2 LEPA G-1600 :perfido: e 4 EVGA 780ti Classified K|NGP|N Edition :coolsmiley:
Microcool Banchetto 101
attachment.php?attachmentid=133129&d=1415089317 attachment.php?attachmentid=133130&d=1415089343 attachment.php?attachmentid=133131&d=1415089379 attachment.php?attachmentid=133132&d=1415089406 attachment.php?attachmentid=133133&d=1415089430 attachment.php?attachmentid=133150&d=1415090017 attachment.php?attachmentid=133151&d=1415090051 attachment.php?attachmentid=133149&d=1415089983
2 LEPA G1600
attachment.php?attachmentid=133134&d=1415089466 attachment.php?attachmentid=133141&d=1415089698 attachment.php?attachmentid=133135&d=1415089493 attachment.php?attachmentid=133136&d=1415089550 attachment.php?attachmentid=133137&d=1415089576 attachment.php?attachmentid=133140&d=1415089664 attachment.php?attachmentid=133138&d=1415089607attachment.php?attachmentid=133139&d=1415089637
4 Enermax Apollish 140mm
attachment.php?attachmentid=133142&d=1415089778 attachment.php?attachmentid=133144&d=1415089852 attachment.php?attachmentid=133147&d=1415089890 attachment.php?attachmentid=133148&d=1415089917
Intel i7-4960X, 64GB Corsair Dominator Platinum kit, EVGA X-79 Dark, Swifthech H320,
attachment.php?attachmentid=133152&d=1415090188 attachment.php?attachmentid=133153&d=1415090218 attachment.php?attachmentid=133154&d=1415090251
4 SLI EVGA 780ti Classified K|NGP|N Edition
attachment.php?attachmentid=133163&d=1415090660 attachment.php?attachmentid=133156&d=1415090418 attachment.php?attachmentid=133157&d=1415090453 attachment.php?attachmentid=133158&d=1415090477 attachment.php?attachmentid=133159&d=1415090515 attachment.php?attachmentid=133155&d=1415090382 attachment.php?attachmentid=133160&d=1415090547 attachment.php?attachmentid=133161&d=1415090575 attachment.php?attachmentid=133162&d=1415090598 attachment.php?attachmentid=133164&d=1415090692 attachment.php?attachmentid=133165&d=1415090725
Alcuni test con 3D Mark Fire Strike, 2SLI 19619, 3SLI 23553 e 4 SLI 25980
attachment.php?attachmentid=133166&d=1415091102 attachment.php?attachmentid=133167&d=1415091129 attachment.php?attachmentid=133168&d=1415091150
Edited by Col. Hannibal
Ciao Ragazzi,
oggi mi sono deciso ad iniziare una fase che mi impensieriva un po': la Verniciatura, anche se si tratta della verniciatura delle parti interne.
In teoria avrei potuto non farla ma così il tutto sarà più pulito ed ordinato, la problematica vista la complessità delle T.d.R. era come procedere, verniciarle tutte assemblate o smontarle e fare le varie parti.
Chiaramente io ho scelto la seconda opzione, visto però il numero delle parti ne farò una alla volta e vernicerò prima la struttura e poi le parti smontate in modo da non mischiarle e rimettere tutto al proprio posto, alla fine dopo aver assemblato e provato le coperture in plexy se ci sarà bisogno darò un'ultima mano.
Ma partimo dalla torre che ho dovuto smontare, togliere il nastro carta residuo, stuccare qualche foro in più, cartavetrare e pulire con acetone
attachment.php?attachmentid=133179&d=1415112698 attachment.php?attachmentid=133180&d=1415112724 attachment.php?attachmentid=133182&d=1415112762 attachment.php?attachmentid=133183&d=1415112799 attachment.php?attachmentid=133184&d=1415112819 attachment.php?attachmentid=133185&d=1415112848 attachment.php?attachmentid=133186&d=1415112882 attachment.php?attachmentid=133187&d=1415112912 attachment.php?attachmentid=133188&d=1415112941 attachment.php?attachmentid=133189&d=1415112966
Via con il Primer
attachment.php?attachmentid=133190&d=1415113002 attachment.php?attachmentid=133191&d=1415113027 attachment.php?attachmentid=133192&d=1415113048
Ecco qua la vernice superficialmente è già asciutta se nei prossimi gg regge queste bombolette marca OBI non sono male...
comunque darò un'altra mano perchè ho finito la bomboletta...
attachment.php?attachmentid=133234&d=1415123061 attachment.php?attachmentid=133236&d=1415123092 attachment.php?attachmentid=133237&d=1415123153 attachment.php?attachmentid=133238&d=1415123177 attachment.php?attachmentid=133239&d=1415123205 attachment.php?attachmentid=133240&d=1415123238 attachment.php?attachmentid=133241&d=1415123266
Effettivamente così fa un'altro effetto e sopra c'è un'altro strato di alluminio che ho smontato da rimettere su asd.gif
Ecco qua la seconda T.d.R e poi insieme con il case il colore è nero opaco, ci sono delle imperfezione ed in foto tra luce e flash viene abbastanza male...
Ma sta molto meglio di prima
attachment.php?attachmentid=133614&d=1415296229 attachment.php?attachmentid=133615&d=1415296252 attachment.php?attachmentid=133616&d=1415296283 attachment.php?attachmentid=133618&d=1415296350 attachment.php?attachmentid=133619&d=1415296387 attachment.php?attachmentid=133620&d=1415296407 attachment.php?attachmentid=133621&d=1415296431
Per queste parti avevo finito il nero,
comunque anche le T.d.R. hanno bisogno di qualche ritocco sia in aggiunta che a togliere
Questo è il prossimo obbiettivo
  • 2 weeks later...
Ciao Ragazzi,
dopo una settimana di lavoro in trasferta non mi ricordo nemmeno più dove eravamo rimasti, allora settimana scorsa avevo verniciato un po' tutte le parti interne del case diciamo la struttura portante
attachment.php?attachmentid=134800&d=1415988390 attachment.php?attachmentid=134802&d=1415988432
Stasera ho ripreso in mano le T.d.R. e i supporti per Aquatube ed Aqua Filter, un bel set di viti e sono andato a montare queste viti che serviranno a fissare il plexy e le famose griglie.
Nell'alloggiamento delle teste delle viti ho usato della bicomponente e per ora le ho messe in posizione stringendole con un dado prigioniero che poi toglierò, le viti hanno varie lunghezze a seconda che devono tenere anche la griglia oppure no
attachment.php?attachmentid=134806&d=1415988615 attachment.php?attachmentid=134807&d=1415988639 attachment.php?attachmentid=134808&d=1415988665 attachment.php?attachmentid=134809&d=1415988689 attachment.php?attachmentid=134810&d=1415988715 attachment.php?attachmentid=134811&d=1415988769
Ed ecco l'effetto con la griglia e la prova con i 2 strati di plexy come da progetto
attachment.php?attachmentid=134812&d=1415988838 attachment.php?attachmentid=134813&d=1415988860 attachment.php?attachmentid=134814&d=1415988882
Visione d'insieme a confronto, le due torri sono pronte entrambe
attachment.php?attachmentid=134815&d=1415988932 attachment.php?attachmentid=134816&d=1415988963 attachment.php?attachmentid=134817&d=1415988998
Vi anticipo che domani sono in una delle sedi segrete dell'EMF a lavorare il Plexy con il nostro C3r34L KilL3rs, incrocio le dita e spero di potervi far vedere preso qualcosa di molto intrigante :asd:
Ciao Ragazzi,
sabato scorso ho avuto il piacere di tornare a far visita ad una delle sedi dell'EXTREME MODDING FACTORYe di lavorare insieme al grande C3r34L KilL3rs, questa volta ci siamo occupati delle coperture in plexy per il mio case come da progetto, le parti erano già state tagliate con un po' di margine
attachment.php?attachmentid=135330&d=1416329806 attachment.php?attachmentid=135331&d=1416329828 attachment.php?attachmentid=135332&d=1416329855
Le abbiamo poi portate alla misura precisa con questa mega CNC la Frankestein Machine di C3r34L KilL3rs
attachment.php?attachmentid=135334&d=1416329925 attachment.php?attachmentid=135335&d=1416329948 attachment.php?attachmentid=135337&d=1416329969 attachment.php?attachmentid=135338&d=1416330033 attachment.php?attachmentid=135339&d=1416330056 attachment.php?attachmentid=135340&d=1416330110 attachment.php?attachmentid=135341&d=1416330138
Poi siamo passati su quest'altra CNC per fare le lavorazioni più fini ed ecco le 8 parti principali che abbiamo realizzato
attachment.php?attachmentid=135342&d=1416330204 attachment.php?attachmentid=135343&d=1416330229 attachment.php?attachmentid=135344&d=1416330252 attachment.php?attachmentid=135345&d=1416330286 attachment.php?attachmentid=135346&d=1416330371 attachment.php?attachmentid=135347&d=1416330400 attachment.php?attachmentid=135348&d=1416330423
Già che c'ero ho improvvisato un Test di piegatura a caldo su uno sfrido di plexy nero per vedere come reagiva il materiale
attachment.php?attachmentid=135349&d=1416330503 attachment.php?attachmentid=135350&d=1416330528 attachment.php?attachmentid=135351&d=1416330594 attachment.php?attachmentid=135350&d=1416330528
Prova superata, nessun cambiamento di colore, un po di retropiegatura ma penso di controllarla fissando il pezzo al supporto prima di farlo raffreddare wink.gif
Ringrazio ancora C3r34L KilL3rs e Tombino-, la loro decisione di sponsorizzarmi, oltre che ottimo per il mio progetto mi ha permesso di conoscere due ragazzi fantastici che ora posso chiamare veramente Amici Ok.gif
Ciao Ragazzi,
rientrato nel mio laboratorio segreto dopo il week end con C3r34L KilL3rs all' EXTREME MODDING FACTORYsono passato a fare le ultime modifiche al case per poter montare le parti in plexy realizzate e vedere finalmente l'effetto che avevo pensato per le aperture delle ventole, per il quale mi ero ispirato ad un paio di mod che ho visto anche se erano diverse, devo comunque ringraziare Kier, Richard Keirsgieter, un mago del plexy con il quale avevo discusso la cosa e mi a dato vari suggerimenti asd.gif.
Smontato le parti inserite le ultime viti le ho fissate dall'interno con la bicomponente
attachment.php?attachmentid=135484&d=1416334978 attachment.php?attachmentid=135485&d=1416335005 attachment.php?attachmentid=135486&d=1416335038 attachment.php?attachmentid=135412&d=1416335100 attachment.php?attachmentid=135413&d=1416335120 attachment.php?attachmentid=135414&d=1416340567 attachment.php?attachmentid=135415&d=1416340593 attachment.php?attachmentid=135416&d=1416340622 attachment.php?attachmentid=135417&d=1416340648 attachment.php?attachmentid=135418&d=1416340676
Asciugata la bicomponente ho rifilato un po e sono andato a rimontare le parti rivettandole dove necessario, ho provato velocemente le parti in plexy e sono passato a montare il case e le ventole per fare un fans e plexy test soprattutto per vedere l'effetto anche se non completo
attachment.php?attachmentid=135419&d=1416340763 attachment.php?attachmentid=135421&d=1416340867 attachment.php?attachmentid=135422&d=1416340890 attachment.php?attachmentid=135423&d=1416340915 attachment.php?attachmentid=135424&d=1416340941 attachment.php?attachmentid=135425&d=1416340964 attachment.php?attachmentid=135426&d=1416340989 attachment.php?attachmentid=135427&d=1416341017 attachment.php?attachmentid=135428&d=1416341058 attachment.php?attachmentid=135429&d=1416341086 attachment.php?attachmentid=135430&d=1416341110 attachment.php?attachmentid=135431&d=1416341173 attachment.php?attachmentid=135432&d=1416341197
to be continued.....
