xpak Posted January 31, 2013 Author Share Posted January 31, 2013 Sfogatevi con le foto... posto tutto l'album che ho on line su picasa!!! https://picasaweb.google.com/105112652336813416909/ProjectModRedIce?authuser=0&authkey=Gv1sRgCNrB48K065ezbw&feat=directlink Quote Link to comment Share on other sites More sharing options...
Gianluca92 Posted January 31, 2013 Share Posted January 31, 2013 GRAZIE TOM!!! La vga semplicemente al primo slot! Il collegamento sarà con il WB del chip set per poi andare alla cpu!! devi far finta che quei tubi non ci siano hihih ahhhhh la liquidi Quote Link to comment Share on other sites More sharing options...
xpak Posted January 31, 2013 Author Share Posted January 31, 2013 ahhhhh la liquidi o yes!!! Quote Link to comment Share on other sites More sharing options...
fedemini Posted January 31, 2013 Share Posted January 31, 2013 Un gran bel lavoro complimenti carbonio rosso e bianco sono un ottima combinazione! Quote Link to comment Share on other sites More sharing options...
xpak Posted January 31, 2013 Author Share Posted January 31, 2013 Grazie davvero!!! Quote Link to comment Share on other sites More sharing options...
tom1 Posted January 31, 2013 Share Posted January 31, 2013 nice album Quote Link to comment Share on other sites More sharing options...
One1ros Posted January 31, 2013 Share Posted January 31, 2013 I am Maurizio and I approve this mod! Quote Link to comment Share on other sites More sharing options...
xpak Posted January 31, 2013 Author Share Posted January 31, 2013 I am Maurizio and I approve this mod! Grazie!!! :D Le soddisfazioni sono queste Quote Link to comment Share on other sites More sharing options...
Gianluca92 Posted January 31, 2013 Share Posted January 31, 2013 ma con la vga farai tutto crystal? Quote Link to comment Share on other sites More sharing options...
xpak Posted January 31, 2013 Author Share Posted January 31, 2013 SI!!! Quote Link to comment Share on other sites More sharing options...
xpak Posted February 3, 2013 Author Share Posted February 3, 2013 Qualche dettaglio sul funzionamento del loop: - Rpm Pompa: 2700 rpm (7V) - Flow Rate: 276 l/h - Temp. Liquido: 20.8° oppure - Rpm Pompa: 3000 rpm (7V) - Flow Rate: 340 l/h - Temp. Liquido: 21° Prossima settimana nuove foto con rifiniture finali del mod, che sto ultimando e benchmark!! Quote Link to comment Share on other sites More sharing options...
tom1 Posted February 3, 2013 Share Posted February 3, 2013 ottimo Quote Link to comment Share on other sites More sharing options...
xpak Posted February 15, 2013 Author Share Posted February 15, 2013 Qualche test... e... Superati i 5Ghz!!! http://imageshack.us/photo/my-images/27/555ll.jpg/ Quote Link to comment Share on other sites More sharing options...
Opmet Posted February 15, 2013 Share Posted February 15, 2013 Che temperature però... L'hai scappottato? Fallo... E poi fai troppi pochi gflops, hai aggiornato il linpack? Ti aumentano i gflops e le temperature... Quote Link to comment Share on other sites More sharing options...
xpak Posted February 15, 2013 Author Share Posted February 15, 2013 bhe non sono mica sotto azoto... le temperature sono quelle perchè ci ho dato troppo dentro di vcore secondo me... non è scoperchiata la cpu!!! E per quanto riguarda il linkpack adesso lo aggiorno PS è un 3770k, scalda molto di più rispetto alla versione che hai tu!! Quote Link to comment Share on other sites More sharing options...
Opmet Posted February 15, 2013 Share Posted February 15, 2013 bhe non sono mica sotto azoto... le temperature sono quelle perchè ci ho dato troppo dentro di vcore secondo me... non è scoperchiata la cpu!!! E per quanto riguarda il linkpack adesso lo aggiorno PS è un 3770k, scalda molto di più rispetto alla versione che hai tu!! Effettivamente 1,4v sono un pò tantini per 4,9ghz su un 3770k. Poi IMHO non si fanno stress test come linx su cpu a quelle frequenze, io vado a 5,1ghz sono per benchare... Scalda perchè ha la pasta di me**a tra il die i l'ihs, se fai la cpu cabriolet guadagni sui 20°. Se fai un lavoro coi fiocchi non perdi nemmeno la garanzia Quote Link to comment Share on other sites More sharing options...
xpak Posted February 15, 2013 Author Share Posted February 15, 2013 20°???? dici davvero???? ps benchare vale a dire un super pi? guarda senza stress test sono a 33° ahahahah Quote Link to comment Share on other sites More sharing options...
Opmet Posted February 15, 2013 Share Posted February 15, 2013 Si dai 15° ai 20° in meno ed avresti i core più o meno tutti alla stessa temperatura... Per benchare intendo 3dmark unigine cosa impegnative per pochi (intensi) secondi sulla cpu... Temperatura normale in idle, cambia poco tra un daily da 4.5 e un salto a 5.0. Qui c'è uno screen di Andrea74 con un 3770k scappottato, con le librerie aggiornate faceva 113gflops (il doppio della tua cpu), temp max (con 7000Mb in uso) 73° dopo quasi 17minuti di stress test, c'è anche da considerare la Tamb, lì era fine settembre, un pelo più caldo . http://postimage.org/image/f3l5qh9xr/ Aggiorna le librerie, fai un test con ALL memory e vedi quanti gradi fai dopo 10minuti Io lo scappotterei, altrimenti sarebbe inutile avere un 3770k a liquido, tanto vale tenerlo ad aria. Quote Link to comment Share on other sites More sharing options...
xpak Posted February 15, 2013 Author Share Posted February 15, 2013 se lo faccio a 4,8ghz, sto come lui... Quote Link to comment Share on other sites More sharing options...
Tex Posted February 15, 2013 Share Posted February 15, 2013 Ehehehe e io pensare che me ne sto tranquillo a 4200@1.05v A 4800@1.24v solo per bench e basta.. A scappottare continuo a pensarci, lo faro a breve con il nuovo acquisto in uscita tra qualche mese Quote Link to comment Share on other sites More sharing options...
Opmet Posted February 15, 2013 Share Posted February 15, 2013 se lo faccio a 4,8ghz, sto come lui... Si ma se aggiorni le librerie linpack stai sui 90°... Quote Link to comment Share on other sites More sharing options...
xpak Posted February 15, 2013 Author Share Posted February 15, 2013 Allora... Aggiornate le librerie di linx, versione 11.01.005 Ed ecco la situazione a 4,8ghz, rispetto allo screen da te postato: ImageShack® - Online Photo and Video Hosting Quote Link to comment Share on other sites More sharing options...
Opmet Posted February 16, 2013 Share Posted February 16, 2013 Buono. Tamb? Ma raffreddi solo la cpu col 360 ed il 200? Quote Link to comment Share on other sites More sharing options...
Opmet Posted February 16, 2013 Share Posted February 16, 2013 Doppio post :3 Quote Link to comment Share on other sites More sharing options...
xpak Posted February 16, 2013 Author Share Posted February 16, 2013 Buono.Tamb? Ma raffreddi solo la cpu col 360 ed il 200? temperatura del liquido 21° tamb 20° si la cpu la raffreddo con il 200 e il 360 Quote Link to comment Share on other sites More sharing options...
