zafira101 Posted March 24, 2012 Author Share Posted March 24, 2012 (edited) Monitor presi :clapclap: ora quale migliore connessione?? 1)dVI-D-->DVI-D 2)DP-->VGA 3)DVI-I-->VGA Oppure 1:dvi-i-->dvi-i 2:dp-->hdmi 3:dvi-d-->dvi-d oppure 1)DVI-D-->DVI-D 2)DP-->DVI-D 3)DVI-I-->DVI-I Ditemi ditemi:) Edited March 24, 2012 by zafira101 Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 24, 2012 Share Posted March 24, 2012 ultima Quote Link to comment Share on other sites More sharing options...
zafira101 Posted March 24, 2012 Author Share Posted March 24, 2012 ultima ok o0o0 Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 24, 2012 Share Posted March 24, 2012 qualche foto poi Quote Link to comment Share on other sites More sharing options...
principe andry Posted March 24, 2012 Share Posted March 24, 2012 1)DVI-D-->DVI-D2)DP-->DVI-D 3)DVI-I-->DVI-I L'ultima è comunque un "DVI-I o D -> DVI-D". Puoi farla così o con l'adattatore DP -> VGA che forse costa un poco meno. ciao Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 24, 2012 Share Posted March 24, 2012 faglela sfruttare la dvi Quote Link to comment Share on other sites More sharing options...
zafira101 Posted March 24, 2012 Author Share Posted March 24, 2012 No visto che devo usare per forza una dvi-d tanto vale fare tutto in digitale. Potrei come alternativa prendere un adatattore DP-->HDMI e risparmiarmi un cavo DVI-D, pero' non so se ci potrebbero essere problemi di colore in quanto ho letto un post su questo monitor che attacato tramite hdmi i colori diventano sbiaditi. Anche se per il momento ne ho attacati 2 uno in DVI-D e uno in HDMI e differenze non ne vedo non vorrei che magari con la DP trovo la sorpresa. Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 24, 2012 Share Posted March 24, 2012 no non avresti problemi come dici Quote Link to comment Share on other sites More sharing options...
zafira101 Posted March 25, 2012 Author Share Posted March 25, 2012 Eccovi 2 fotine tanto per gradire, chiaramente deve arrivare il terzo monitor e c'e' da sistemare i pannelli Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 25, 2012 Share Posted March 25, 2012 finalmente , grande Quote Link to comment Share on other sites More sharing options...
zafira101 Posted March 25, 2012 Author Share Posted March 25, 2012 mi tocchera' aspettare che mi arrivi l'adattatore per vedererli tutti e tre in funzione Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 25, 2012 Share Posted March 25, 2012 già cosi rendono però Quote Link to comment Share on other sites More sharing options...
zafira101 Posted March 25, 2012 Author Share Posted March 25, 2012 Domani metto in vendita il samsung da 22" a led Quote Link to comment Share on other sites More sharing options...
zafira101 Posted March 25, 2012 Author Share Posted March 25, 2012 Sono solo in dubbio per l'adattatore del DP, se prenderlo HDMI o DVI Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 25, 2012 Share Posted March 25, 2012 prendilo dvi Quote Link to comment Share on other sites More sharing options...
zafira101 Posted March 27, 2012 Author Share Posted March 27, 2012 Eccomi qua vi posto 2 fotine del sistema in funzione, al momento e' collegato in questo modo: DP-->dvi HDMI DVI-D poi quando sistemo tutto verranno connessi tutti e 3 in dvi, se avete sugerimenti sono ben accetti. Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 28, 2012 Share Posted March 28, 2012 veramente un ottimo lavoretto Quote Link to comment Share on other sites More sharing options...
principe andry Posted March 29, 2012 Share Posted March 29, 2012 Ottimo, sei riuscita nell'impresa Forse hanno un angolo un pochino accentuato, ma non puoi fare altrimenti. Mi sembra che gli AOC abbiano una tonalità un po' troppo fredda; forse è il caso di diminuire di qualche punticino il colore blu nel menù OSD. Puoi magari aiutarti con questo sito per trovare il setting più appropriato -> click ciao Quote Link to comment Share on other sites More sharing options...
tom1 Posted March 29, 2012 Share Posted March 29, 2012 dalla foto non sembrà Quote Link to comment Share on other sites More sharing options...
Janluk Posted May 4, 2012 Share Posted May 4, 2012 Ciao a Tutti, vi scrivo perchè sono rimasto impressionato dall'opportunità di avere il multi monitor (eyefinity). Sarei intenzionato ad acquistare una hd 7970 e su questo credo non ci siano problemi. Il mio problema sorge per i 3 monitor da appaiare. Ora possiedo un monitor LG e2441v BN Led 24" che ha come collegamenti; D-SUB quantità 1 DVI-D quantità 1 HDMI quantità 1 Se comprassi altri 2 monitor dello stesso modello di quello in mio possesso, eyefinity sarebbe fattibile o devo palesemente comprare altri 3 monitor con attacchi diversi? Grazie anticipatamente per la risposta. Quote Link to comment Share on other sites More sharing options...
tom1 Posted May 4, 2012 Share Posted May 4, 2012 Ciao a Tutti, vi scrivo perchè sono rimasto impressionato dall'opportunità di avere il multi monitor (eyefinity). Sarei intenzionato ad acquistare una hd 7970 e su questo credo non ci siano problemi. Il mio problema sorge per i 3 monitor da appaiare. Ora possiedo un monitor LG e2441v BN Led 24" che ha come collegamenti; D-SUB quantità 1 DVI-D quantità 1 HDMI quantità 1 Se comprassi altri 2 monitor dello stesso modello di quello in mio possesso, eyefinity sarebbe fattibile o devo palesemente comprare altri 3 monitor con attacchi diversi? Grazie anticipatamente per la risposta. ciao passa a presentarti qui Presentazione nuovi utenti poi si sarebbe fattibilissima la situazione Quote Link to comment Share on other sites More sharing options...
Janluk Posted May 4, 2012 Share Posted May 4, 2012 Benissimo, (grazie, grazie, grazie) allora attendo che arrivi il supporto per i tre monitor la scheda e successivamente i due monitor aggiuntivi LG 24". Non voglio sembrare logorroico appena arrivato e fare 3000 domande, ma i diversi adattatori da utilizzare per i collegamenti consentiranno una qualità video di tutto rispetto? Non vorrei fare pasticci vista la spesa a cui andrò in contro. Comunque quando avrò tutto vi interpellerò ancora per chiedervi dettagli. Felice come una Pasqua saluto. P.S. mi sono presentatoO0 Quote Link to comment Share on other sites More sharing options...
tom1 Posted May 4, 2012 Share Posted May 4, 2012 Certo le uscite DVI e HDMi hanno entrambe un collegamento Digitale quindi la qualità sarà ottima, ovviamente dipende anche dalla qualità dei monitor Quote Link to comment Share on other sites More sharing options...
Janluk Posted May 4, 2012 Share Posted May 4, 2012 (edited) Grazie ancora mi farò sentire! Presto :n2mu: Edited May 4, 2012 by Janluk Quote Link to comment Share on other sites More sharing options...
tom1 Posted May 5, 2012 Share Posted May 5, 2012 Quote Link to comment Share on other sites More sharing options...
