toretto0921 Posted January 26, 2012 Author Share Posted January 26, 2012 scrivendo directx 11 mi trova la 9.29.1962 Quote Link to comment Share on other sites More sharing options...
tom1 Posted January 26, 2012 Share Posted January 26, 2012 DirectX 11.rar Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 26, 2012 Author Share Posted January 26, 2012 edit mi hai anticipato adesso provo Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 26, 2012 Author Share Posted January 26, 2012 stesso risultato... mi crasha sempre quando sta per partire la gara... si sente il motore della macchina e crasha all'istante... Quote Link to comment Share on other sites More sharing options...
tom1 Posted January 26, 2012 Share Posted January 26, 2012 come driver a che versione sei ? Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 26, 2012 Author Share Posted January 26, 2012 ho i catalyst 12.1 installate stamattina Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 27, 2012 Author Share Posted January 27, 2012 allora ragazzi? Quote Link to comment Share on other sites More sharing options...
tom1 Posted January 27, 2012 Share Posted January 27, 2012 mmmmm Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 27, 2012 Author Share Posted January 27, 2012 non posso giocarci? Quote Link to comment Share on other sites More sharing options...
tom1 Posted January 27, 2012 Share Posted January 27, 2012 riprova con un punto di ripristino Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 27, 2012 Author Share Posted January 27, 2012 ma secondo me non cambia niente perchè anche al ragazzo del video che ho postato precedentemente dava lo stesso problema quando installava la directx Quote Link to comment Share on other sites More sharing options...
principe andry Posted January 27, 2012 Share Posted January 27, 2012 (edited) Nelle impostazioni audio, metti 24 bit 44100 Hz. Il problema delle DX non dovrebbe essere collegato al crash del gioco. ciao Edited January 27, 2012 by principe andry Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 27, 2012 Author Share Posted January 27, 2012 Nelle impostazioni audio, metti 24 bit 44100 Hz.Il problema delle DX non dovrebbe essere collegato al crash del gioco. ciao azzzzzzzzz sei un genio adesso funzionaaaa!!! Quote Link to comment Share on other sites More sharing options...
principe andry Posted January 27, 2012 Share Posted January 27, 2012 Ottimo ciao Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 27, 2012 Author Share Posted January 27, 2012 adesso c'è un'altro problemino... mentre gioco la scheda mi arriva a 70 gradi... come mai temperature così alte di inverno e soprattutto in dx9? poi ho notato anche micro lag Quote Link to comment Share on other sites More sharing options...
principe andry Posted January 27, 2012 Share Posted January 27, 2012 La temperatura è più che accettabile. Puoi magari agire nelle impostazioni della ventola che forse sta girando a bassi regimi. Hai notato lag nei comandi? Con che periferica giochi? Lo fa solo questo? La patch 1.1 mi sembra che non vada a correggere un problema del genere, ma intanto la metterei. ciao Quote Link to comment Share on other sites More sharing options...
toretto0921 Posted January 27, 2012 Author Share Posted January 27, 2012 la ventola di solito quando gioco la metto a 60%... i lag sono mentre gioco, gioco con il controller della xbox360... la patch 1.1 l'ho già messa Quote Link to comment Share on other sites More sharing options...
principe andry Posted January 27, 2012 Share Posted January 27, 2012 Le temp come detto non sono un problema quindi vedi te se è il caso di aumentare la percentuale o lasciare la gestione in auto. C'è un menù in cui è possibile settare la zona morta e roba varia? Ricordo un problema analogo su Shift 2. Purtroppo dovrai cercare un giusto setting tra quelle voci (se ci sono), oppure cerca sul web se altri hanno risolto in qualche modo ciao Quote Link to comment Share on other sites More sharing options...
Zicchette Posted February 18, 2012 Share Posted February 18, 2012 Nelle impostazioni audio, metti 24 bit 44100 Hz.Il problema delle DX non dovrebbe essere collegato al crash del gioco. ciao ciao a tutti.... anch'io ho lo stesso problema ma non ho capito dove devo inserire queste impostazioni audio per farlo funzionare...potete spiegarmelo? grazie Quote Link to comment Share on other sites More sharing options...
principe andry Posted February 18, 2012 Share Posted February 18, 2012 Ciao, puoi presentarti qui -> click Quell'impostazione la devi modificare nel pannello di controllo audio. Trovi un'icona nella barra degli strumenti (in basso a destra dove c'è l'orologio) oppure ci arrivi dal pannello di controllo (audio - proprietà su altoparlanti - avanzate). ciao Quote Link to comment Share on other sites More sharing options...
