Febry Posted April 16, 2005 Share Posted April 16, 2005 Ekko cosa sono riuscito ad ottenere con lami a 6600GT della Albatron, sulla quale ho montato un bello Zalman VF-700.... Quote Link to comment Share on other sites More sharing options...
DarkEviL Posted April 16, 2005 Share Posted April 16, 2005 Ho appena provato a fare il 3d mark 2003 (non ho la cpu in oc) [attachmentid=1] cpu:atlhon 64 newcaste 3500+ (201@2211Mhz) m/b:Asus A8N SLI Deluxe RAM:2 * 512 MB A-DATA Vitesta 566 (201@2-2-2-5) Sk video:Point of view (games edition) 6600 GT (595@1.15 Ghz) HD: 4 * 200 GB Maxtor sata - 2 * raid 0 Ali: Enermax 535 W Full air cooling Zalman VF700 Cu e Zalman 7000 Cu Quote Link to comment Share on other sites More sharing options...
Peppe Posted April 16, 2005 Share Posted April 16, 2005 grande dark e feb. per? secondo me dark...se spingi per bene la cpu arrivi sui 10000. facci ved? Quote Link to comment Share on other sites More sharing options...
Febry Posted April 17, 2005 Author Share Posted April 17, 2005 anceh sec me... manda la cpu almeno a 2700 mhz e vedrai ceh superi alla grande i 10 000 punti!!! facci vedere!!! Quote Link to comment Share on other sites More sharing options...
SACD Posted April 18, 2005 Share Posted April 18, 2005 be, quel test nn ? molto cpu limited... Quote Link to comment Share on other sites More sharing options...
Febry Posted April 19, 2005 Author Share Posted April 19, 2005 bhe...sarebbe meglio fare un 2005?? Quote Link to comment Share on other sites More sharing options...
SACD Posted April 19, 2005 Share Posted April 19, 2005 bhe...sarebbe meglio fare un 2005?? 104[/snapback] NN credo sia il 2300 che il 2500 tengono conto poco della potenza del processore, chiaro entro certi limiti, certo che da A64 3200+ e 3500+ a pari di scheda video nn cambia nulla Quote Link to comment Share on other sites More sharing options...
MAGNO Posted April 19, 2005 Share Posted April 19, 2005 ho montato lo zalman proprio ora e arrivo a 600 di core e posso aumentare la ram fino a 1250 circa.. mi restituisce con un xp@ 2310 mhz 1.25 gb ram @ 171 di bus un onestissimo 3878 al 2005. provero' a fare una vmod il prima possibile magari delicata @ 1.45 v in modo da eliminare gli artefatti che oni tanto arrivano e da salire ancora un po. aprendo il bios con nibitor si pou' mettere il core solo a 1.4v, secondo voi usando un editor esadecimale e' possibile alzare di + da bios? Quote Link to comment Share on other sites More sharing options...
Peppe Posted April 19, 2005 Share Posted April 19, 2005 be, quel test nn ? molto cpu limited... 88[/snapback] ti quoto in parte in quanto anke se il 3d mark 2003 e il 2005 sono meno cpu limited rispetto al 2001 in generale una cpu + veloce riesce a sfruttare meglio la gpu riducendo al minimo il cos? detto collo di bottiglia. questo nn ? fondamentale solo per i bench su visti ma anke per i gioki molto esosi anke in fatto di requisiti. prendiamo ad esempio doom3 ke fatto lavorare cn 1Gb di ram rispetto a 512Mb ? tutta un'altra cosa. ora tornando IT , anke se il miglioramento nel bench nn sar? sostanziale, qualke centinaio di punti li prende sempre IMHO . ciauz Quote Link to comment Share on other sites More sharing options...
SACD Posted April 19, 2005 Share Posted April 19, 2005 ti quoto in parte in quanto anke se il 3d mark 2003 e il 2005 sono meno cpu limited rispetto al 2001 in generale una cpu + veloce riesce a sfruttare meglio la gpu riducendo al minimo il cos? detto collo di bottiglia. questo nn ? fondamentale solo per i bench su visti ma anke per i gioki molto esosi anke in fatto di requisiti. prendiamo ad esempio doom3 ke fatto lavorare cn 1Gb di ram rispetto a 512Mb ? tutta un'altra cosa. ora tornando IT , anke se il miglioramento nel bench nn sar? sostanziale, qualke centinaio di punti li prende sempre IMHO .ciauz 158[/snapback] Si ma dipende sempre dalla scheda video che ha su, nn credo che una 6600gt metta in crisi il processore... Quote Link to comment Share on other sites More sharing options...
Peppe Posted April 19, 2005 Share Posted April 19, 2005 in crisi no, ma rimango dell'opinione ke le skeda video di fascia medio/alta siano limitate ki + ki - dalla cpu Quote Link to comment Share on other sites More sharing options...
MAGNO Posted April 19, 2005 Share Posted April 19, 2005 in crisi no, ma rimango dell'opinione ke le skeda video di fascia medio/alta siano limitate ki + ki - dalla cpu 162[/snapback] qlc bench e' limitato dalla cpu, il peggiore da questo punto di vista sono al primo posto il 3dmark 2001, poi aquamark, poi il 2003 e infine il 2005 che e' quello + veritiero. per spremere di + ste 6600 armatevi di google e cercate se e' possibile modificare il bios per aumentare il voltaggio gpu oltre i 1.4v, visto che che sembrano possibili a 1.6v i 630 mhz di core. Quote Link to comment Share on other sites More sharing options...
Febry Posted April 19, 2005 Author Share Posted April 19, 2005 qlc bench e' limitato dalla cpu, il peggiore da questo punto di vista sono al primo posto il 3dmark 2001, poi aquamark, poi il 2003 e infine il 2005 che e' quello + veritiero. per spremere di + ste 6600 armatevi di google e cercate se e' possibile modificare il bios per aumentare il voltaggio gpu oltre i 1.4v, visto che che sembrano possibili a 1.6v i 630 mhz di core. 167[/snapback] quoto in pieno.... ma visto che se il mod della sezione...xche nn ti dai da fare e ce lo cerchi tu? ghhghghg dai dai dai!! so curioso!! facci sapere!! Quote Link to comment Share on other sites More sharing options...
SACD Posted April 19, 2005 Share Posted April 19, 2005 Fare una modifica di questo tipo sulla 6600gt rimane un fine a se stesso, perch? varrebbe di pi? la pena farlo su una 6800 liscia moddata, li si visto il bus pi? ampio sarebbe curioso :P Quote Link to comment Share on other sites More sharing options...
MAGNO Posted April 19, 2005 Share Posted April 19, 2005 quoto in pieno....ma visto che se il mod della sezione...xche nn ti dai da fare e ce lo cerchi tu? ghhghghg dai dai dai!! so curioso!! facci sapere!! 170[/snapback] lol... siccome sono tipo 2 ore che sto qua davanti a cercare e ho gli occhi sfoderati, vi riassumo quell oche ho trovato, tra un accozzaglia di siti spagnoli tedeschi, inglesi e francesi. ( chiaramente in italiano il nulla) allora punto primo la mod via bios non e' possibile. c'e un valore per la gpu ( bisogna aprire il bios con editor esadecimale) di numero 8C che corrisponde all'id 4 dei 1.4v anche cambiandolo non succede nulla. non si sa per limitazione del regolatore di tensione o se siano i driver che intervengono a rompere la festa. ma siccome ho trovato che le 6800 si modificano a 1.5v suppongo che siamo fregati e non sia un problema di driver. l'unica e' la vmod con ( a quanto visto ) l'applicazione di una resistenza da 420 ohm che piloti il reg di tens a 1.6v. http://forum.hardware.fr/hardwarefr/Overcl...et-243885-1.htm in questa discussione troverete qlc cosa di utile. cmq nelle mie ricerche ho trovato un tizio che ha tirato fuori dalla gpu 640 mhz. questo e' lo schema logico del regolatore di tensione: visto che la tensione deriva dal rapporto di r1 con r4 facile supporre che variando una della due cambi la V di uscita. inoltre come si era gia visto su hw upgrade e che ho sperimentato oggi e' possibile usando rivatuner disabilitare il check dei driver ( a patto di fare il cambio con lo stesso rivatuner) senza artefatti ho guadagnato altri 20 mhz arrivando a 1240 circa. basta andare sotto power user.... Nvidia overclocking .... disableinternalclocktest e settare il valore a 1 Quote Link to comment Share on other sites More sharing options...
Febry Posted April 19, 2005 Author Share Posted April 19, 2005 azz nn sembra pero' semplice.... bela lavoro MAGNO!!! Quote Link to comment Share on other sites More sharing options...
MAGNO Posted April 19, 2005 Share Posted April 19, 2005 azznn sembra pero' semplice.... bela lavoro MAGNO!!! 177[/snapback] sulla mia 9500 @ pro @ 383 bios mod @ 336 mem l'avevo fatta senza grossi problemi. qua il problema dovrebbe essere che a pilotare la tens bisogna attaccarsi alle res gia esistenti che sono minuscole e non al regolatore stesso che e' + grande e + facile da saldare. quando avro' certezze e coraggio la faro' Quote Link to comment Share on other sites More sharing options...
Febry Posted April 19, 2005 Author Share Posted April 19, 2005 ottimo !! aspettiamo con ansia! Quote Link to comment Share on other sites More sharing options...
DarkEviL Posted April 22, 2005 Share Posted April 22, 2005 ragazzuoli... cmq ho testato... con core... della cpu a 2500 Mhz e gpu a 250@1.200 (a questi settaggi non mi da nessun artefatto) e sono arrivato a 9700 di 3dmark 2003 quindi pi? o meno 300 punti in + ! per? i 10000 nada :| dovrei alzare il core della gpu per? poi vengono fuori artefatti (quelle cosette verdi) e mi danno fastidio... cmq sono sicuro che se porto a 600 Mhz la gpu i 10000 li supererei tranquillamente! Per rispondere a MAGNO se alza la frequenza della cpu.. ? normale che il 3dmark(2003 come il 2005).. ti dia un punteggio pi? alto sato.. che se ci fai caso poi fa 2 test utilizzando la cpu come rendering 3d! un saluto a tutti gli overclokkers! ottimo !!aspettiamo con ansia! 207[/snapback] Quote Link to comment Share on other sites More sharing options...
Febry Posted April 23, 2005 Author Share Posted April 23, 2005 ciao dark, volevo solo dirti che con la cpu a soli 2500 mhz i 10 000 nn li vedi di sicuro... minimo la devi mandare a 2600mhz... Quote Link to comment Share on other sites More sharing options...
MAGNO Posted April 23, 2005 Share Posted April 23, 2005 esatto, ora avete capito perch? dicevo che 8800 era il massimo che potessi tirare fuori con un vecchio processore come il mio Quote Link to comment Share on other sites More sharing options...
Febry Posted April 23, 2005 Author Share Posted April 23, 2005 e gi?.... :( Quote Link to comment Share on other sites More sharing options...
DarkEviL Posted April 23, 2005 Share Posted April 23, 2005 ciao dark, volevo solo dirti che con la cpu a soli 2500 mhz i 10 000 nn li vedi di sicuro...minimo la devi mandare a 2600mhz... 389[/snapback] Compare Febry prover? poi a cloccare a 2600 e alzare di pi? il core della gpu... vediamo se li raggiungo.. per ora sono a 9700 di 3d mark 2003 cpu:atlhon 64 newcaste 3500+ (250*10@2500Mhz) m/b:Asus A8N SLI Deluxe RAM:2 * 512 MB A-DATA Vitesta 566 (250@2.5-3-3-5) Sk video:Point of view (games edition) 6600 GT (595@1.15 Ghz) HD: 4 * 200 GB Maxtor sata - 2 * raid 0 Ali: Enermax 535 W Full air cooling Zalman VF700 Cu e Zalman 7000 Cu Quote Link to comment Share on other sites More sharing options...
Febry Posted May 5, 2005 Author Share Posted May 5, 2005 ragazzi mi consigliate i migliori driver le la mia 6600 GT? grassie Quote Link to comment Share on other sites More sharing options...
januka Posted May 5, 2005 Share Posted May 5, 2005 ragazzi mi consigliate i migliori driver le la mia 6600 GT?grassie 746[/snapback] ciao, io ho appena installato i Forceware 76.44 Win2000/XP WHQL e mi sembrano ottimi. tutto a default e sistema sporco dopo aver giocato 2 ore a far cry ho fatto 3dmark2005 e fatto 4040 punti che non dovrebbero essere male Quote Link to comment Share on other sites More sharing options...
